dakinman
#1 Posted : Monday, November 24, 2008 2:32:02 PM(UTC)
dakinman
Burners won't ignite without lighting them with a match.
While all burners are lit I can turn one off and it will ignite itself, but when I turn them all off I have to start with a match.
Everything is clean, nothing clogged or spilled on them.
I'm thinking I might need to replace the Spark Module but want to make sure before I do.I do get them to spark and light themselves after I light them with a match but after their turned off, no spark or ignition.
Thanks for your time.
libertyappl
#2 Posted : Tuesday, November 25, 2008 11:18:59 AM(UTC)
libertyappl
You are correct, it's probably your spark module.
Nat
jcsargent
#3 Posted : Wednesday, April 29, 2009 5:04:26 AM(UTC)
jcsargent
the ge model has two different spill pans. if you swap them the burners will not sit flush on the cooking surface and the burners will not light.
GE Profile Ignitor problems (Oven Repair (including Ranges and Cooktops))
by Brent Feathers 8/3/2012 8:54:02 AM(UTC)
