My Thermador rdds30vrs oven will not work. Range works fine. Oven light turns on, clock works. Every time I press any of the buttons on control panel, "off" comes on display for 5 seconds, then goes away. None of the buttons work. What do I do?.
Originally Posted by: stbresina  My Thermador rdds30vrs oven will not work. Range works fine. Oven light turns on, clock works. Every time I press any of the buttons on control panel, "off" comes on display for 5 seconds, then goes away. None of the buttons work. What do I do?. STB, Sounds like someone accidentally programmed a "lockout" program for the oven. Or maybe a bad ERC(clock/control). You may have to get your User's Manaual out and recheck how to reset the lockout mode. :cool: :cool: :cool:
Does anyone know how to get at the control panel on a Thermador RDDS30VRS Stove.
Is there a Service Manual on this site to look at? My control panel (manu. part#486752) is going dim
Originally Posted by: bsprtsgrp  Does anyone know how to get at the control panel on a Thermador RDDS30VRS Stove.
Thanks Sorry, My access to certain products and brands is limited. We do not have on line service manuals on our site , at this time. Several of our technical contributors may ahve access to the information and may be able to assist you, :o :o :o
