Replacement parts for MAYTAG MSD2656DEB REF - SXS/I&W | AppliancePartsPros.comHere is a manual which should help. It does not specifically list yout unit but it should be close.
16010154 Maytag Refrigerator Service Manual - ApplianceDigest.comYou have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
[COLOR="DarkRed"]But why is the compressor constantly running?[/COLOR]
Since the fan cannot pull air through the evaporator coils so the air does not cool properly so the unit runs all the time trying to get the freezer down to set point. Basically the unit is now a freezer with a large ice cube in it (iced up evaporator).
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle (see the manual) (Item 13 in Section 2) when the fans and compressor turn off, you are in defrost.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the defrost board needs replacing.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element/thermostat combo (Item 12 in Section 4) from the wiring and measure it for continuity, usually around 20 ohms or so. The thermostat is wired in series with the heating element. It shuts the element off once all the ice has melted off the evaporator coils.
Note that the defrost thermostat opens just above freezing so must be frozen to check the assembly. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost board is toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
