lalyzea
#1 Posted : Friday, November 21, 2008 3:04:24 PM(UTC)
lalyzea
my machine does not stop filling up even if I put it on small load. I also need help on how do I take apart the control panel.
#2 Posted : Friday, November 21, 2008 4:06:33 PM(UTC)
Remove the screw on each bottom side on the back of the control panel (#49 on the break down diagram). Pull the console forward and up to remove the tabs on the bottom of the end caps, out of the holes in the top. Lift the console up and lay it on its back.
Check if the pressure hose (clear plastic hose) is properly connected to the water level switch.
Here are the break down diagrams for the Whirlpool washer Model LSN2000JQ2
lalyzea
#3 Posted : Tuesday, November 25, 2008 4:50:16 AM(UTC)
lalyzea
I just want to thank you for helping me solve the problem I was having with my washing machine. It was the hose. My washing machine is running good.
#4 Posted : Thursday, November 27, 2008 6:52:00 PM(UTC)
I'm glad you were able to fix it.
