jsmi
#1 Posted : Wednesday, June 8, 2011 6:34:56 AM(UTC)
jsmi
When I plug it in nothing at all happens? Any suggestions?
#2 Posted : Wednesday, June 8, 2011 7:26:41 AM(UTC)
Here is your parts breakdown.
Replacement parts for WHIRLPOOL EV200NXDW00 VERTICAL FREEZER | AppliancePartsPros.com
Does the interior light work?
Did it work before this problem?
If yes to both the above try a different outlet or check the power at it's current outlet.
If the light does work then you may be in a defrost cycle.
Leave it plugged in for half an hour or so to see if it will come out of defrost by itself.
If it does not manually rotate the timer cam (Item 7 in Section 2) to force it out of defrost. There is usually a hole in the cover to let you do this.
If it does fire up then replace the timer as it is sticking in defrost mode.
