2 Pages12>
phill7
#1 Posted : Thursday, October 30, 2008 2:33:18 PM(UTC)
phill7
recently after doing the self cleaning on the oven, now it doesn't heat up. when it preheats, it starts to beep and the preheat, and bake light goes out and it never heats up. does something need to be replaced or reset?
kayakcrzy
#2 Posted : Saturday, November 1, 2008 6:19:43 AM(UTC)
kayakcrzy
Yes, the clock control board. The part # is 12001628 Tom ApplianceEducator.com
phill7
#3 Posted : Monday, November 17, 2008 4:15:08 PM(UTC)
phill7
the broiler element works, just the baking element giving problems. is that definitely the clock control ? don't want to buy that if it's just the baking element that needs to be replaced. how hard is it to replace the clock or the baking element?
libertyappl
#4 Posted : Monday, November 17, 2008 4:41:18 PM(UTC)
libertyappl
Check for 240V at the bake element.
Nat
kayakcrzy
#5 Posted : Tuesday, November 18, 2008 3:15:01 AM(UTC)
kayakcrzy
I would agree with Nat. Check for power at the element, or pull it, and have it checked. Tom ApplianceEducator.com
phill7
#6 Posted : Sunday, November 23, 2008 1:00:51 PM(UTC)
phill7
replaced baking element since old one wasn't working, but still having problem. Oven goes to preheat then shuts off and periodically beeps for about a half hour. guess I need to replace the control clock but how hard is it to replace?
kayakcrzy
#7 Posted : Monday, November 24, 2008 3:34:15 AM(UTC)
kayakcrzy
That is what it sounds like. I guess there are no codes coming up? Tom ApplianceEducator.com
phill7
#8 Posted : Monday, November 24, 2008 8:17:17 AM(UTC)
phill7
no codes, time stays on clock and just beeps. how hard is it to replace the control clock?
kayakcrzy
#9 Posted : Monday, November 24, 2008 1:35:07 PM(UTC)
kayakcrzy
Take the back off the control panel area, and replace it. It is real easy. Of course unplug the stove before you do it. Tom ApplianceEducator.com
phill7
#10 Posted : Sunday, December 7, 2008 3:02:24 PM(UTC)
phill7
replaced the control clock and now getting F3 error. is it the oven sensor or the wiring that is causing this? and how hard is it to replace the sensor?
Viking gas broiler and oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 12/4/2023 2:39:31 PM(UTC)
Dacor oven, upper oven not working (Oven Repair (including Ranges and Cooktops))
by notyepcars 11/26/2022 8:40:21 AM(UTC)
oven not working, gives me a code F3 (Oven Repair (including Ranges and Cooktops))
by cj9113 10/16/2021 7:56:35 AM(UTC)
GE PROFILE PGB995DET1WW Top oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 9/6/2021 9:36:45 AM(UTC)
Whirlpool microwave/oven not working (Oven Repair (including Ranges and Cooktops))
by naik71 9/3/2020 5:51:16 PM(UTC)
Thermador oven not working DP366CS/03 (Oven Repair (including Ranges and Cooktops))
by Chanmomu 6/30/2020 5:07:14 AM(UTC)
whirlpool WOD93EC0AS double oven bottom oven not working (Oven Repair (including Ranges and Cooktops))
by Chemsal 3/18/2020 3:28:11 AM(UTC)
KDRP467KSS08 / KDRP467KSS0 KitchenAid oven not working (Oven Repair (including Ranges and Cooktops))
by larrywick 10/18/2019 2:28:40 PM(UTC)
Oven On light stays lit - Oven not working properly (Oven Repair (including Ranges and Cooktops))
by Lometir 3/20/2019 7:54:34 AM(UTC)
ge oven not working (Oven Repair (including Ranges and Cooktops))
by mcp1212 9/25/2018 1:00:51 PM(UTC)
maytag range oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by tpwd 3/27/2018 3:28:20 PM(UTC)
Whirlpool Accubake Oven Not Working (Oven Repair (including Ranges and Cooktops))
by buddha61 11/15/2017 5:18:32 PM(UTC)
Maytag oven not working (Oven Repair (including Ranges and Cooktops))
by dtmeyer 10/14/2017 12:48:25 PM(UTC)
Oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by Nalk 1/20/2017 7:05:57 PM(UTC)
stove oven not working but burnerws do (Oven Repair (including Ranges and Cooktops))
by jnevill1 1/1/2017 7:20:12 AM(UTC)
2 Pages12>
