2 Pages<12
#11 Posted : Monday, May 23, 2011 11:43:19 AM(UTC)
Your dishwasher made by Frigidaire and design is very different compare to the dishwashers discussed earlier. Looks like the problem is a bad control board.
- The control board Part number: AP4392629
bpereira
#12 Posted : Monday, June 6, 2011 7:36:35 PM(UTC)
bpereira
Hi Gene,
I have a similar problem. I have a Whirlpool DU930PWPS0 that has the heat dry light blinking permanently. I unplugged the unit and replaced the Electronic Control (part #8546514 or W10039780). When I turned it on, it seemed to be fixed, started draining and suddenly, the dreaded blinking light started up again. I would really appreciate your help!
#13 Posted : Tuesday, June 7, 2011 2:49:01 PM(UTC)
I'm afraid you replaced the control board with no need of it. Most likely the problem is a bad key pad. It comes as a part of the console. If you need the correct part number, post the color of it.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL DU930PWPS0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
2 Pages<12
