DIYGuyDM
#1 Posted : Sunday, November 23, 2008 12:08:24 PM(UTC)
DIYGuyDM
Drain hose not blocked, but getting evap draining through a screw hole in fan housing. Unit has a braided wire loop positioned inside drain tube, going up through evap coil to electrical connection. Possibly not heating correctly, so drain tube freezing up?
icehouse
#2 Posted : Sunday, November 23, 2008 12:28:07 PM(UTC)
icehouse
Ah one word yes
DIYGuyDM
#3 Posted : Sunday, November 23, 2008 12:39:14 PM(UTC)
DIYGuyDM
Thanks. Wire loop has continuity, but quite high resistance. I would have expected that if it's a heating coil.
icehouse
#4 Posted : Sunday, November 23, 2008 12:48:05 PM(UTC)
icehouse
You have learned well "Grasshopper". :)
DIYGuyDM
#5 Posted : Sunday, November 23, 2008 1:22:30 PM(UTC)
DIYGuyDM
So the next question is, how to test whether it's the coil gone bad or the signal to it? Many thanks, O guru.
icehouse
#6 Posted : Sunday, November 23, 2008 1:32:50 PM(UTC)
icehouse
Guest (5)
