LoveMyGolden
#1 Posted : Monday, June 6, 2011 9:39:30 AM(UTC)
LoveMyGolden
Recently, my Whirlpool 8 cycle/2 speed washing machine is leaving me with a gallon or more of water in the bottom, leaving my clothes soaking wet! I noticed it rinses and drains perfectly fine on the 1st rinse/spin cycle, but the final cycle is where it is not completely draining. What is causing this? What part would I need replaced as we would like to fix it ourselves.
sidfink43
#2 Posted : Wednesday, June 8, 2011 6:31:36 AM(UTC)
sidfink43
Since it is working correctly through one cycle, that suggests that the problem is not mechanical but electrical. I would try replacing the timer, it is a relatively easy job that you should be able to do just fine.
LoveMyGolden
#3 Posted : Wednesday, June 8, 2011 11:00:29 AM(UTC)
LoveMyGolden
Thanks Sidfink43...I wasn't sure if it was that or a pump. (Also, don't know if I clarified this... it does actually spin on the last spin cycle, just that the water isn't drained out.) Thanks again!
