Veronica R
#1 Posted : Sunday, May 29, 2011 9:59:49 AM(UTC)
Veronica R
My Refrigerator is an Amana (11 yrs old) model # BB20VPSE (when choosing the correct one, of the two listed on this site, I used the one with the W E on the end.... MFG# is P1321302 W E)
I've read a lot of the posts written on here regarding this problem and have already replaced the defrost timer but the problem still exists. I don't own nor do I understand how to use an Ohmmeter. (This is my first attempt at repairing an appliance rather than calling a repairman, so I am still learning.)
Here's what I have done, so far.... Removed the inside, back wall of the freezer compartment (bottom freezer) and found the defrost heater (also known as a condenser coil, I think, No?) full of ice. Used a hair dryer, and removed the ice (drained into the pan below with no problem). Plugged frig back in and it worked fine for about a day. Then the ice was back and same problem returned. Replaced the defrost timer, used hair dryer to remove ice again and tried again. Another day working fine, but then same problem returned. Was going to attempt to replace the defrost heater, or even the defrost thermostat, but neither part was available... not sure what to do now?
Can you help to find the correct part or would you suggest I call a repairman in now, before I cause any further problems?
Veronica R
#2 Posted : Wednesday, June 1, 2011 1:03:31 PM(UTC)
Veronica R
Could really use an answer to my question below regarding the correct part that needs to be replaced! Can anyone here help me?
Originally Posted by: Veronica R Go to Quoted Post
My Refrigerator is an Amana (11 yrs old) model # BB20VPSE (when choosing the correct one, of the two listed on this site, I used the one with the W E on the end.... Manufacturer# is P1321302 W E)
#3 Posted : Thursday, June 2, 2011 2:37:28 AM(UTC)
Replacement parts for BB20VPSE models | AppliancePartsPros.com
Below is my blurb on defrost problem troubleshooting/repair
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 43 in Section 8) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 23 in Section 8) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
Veronica R
#4 Posted : Monday, June 6, 2011 6:55:49 AM(UTC)
Veronica R
Thank you for the help. Turns out it was the defrost thermostat that was bad. Replaced it and now the unit is working great! :)
Originally Posted by: denman Go to Quoted Post
If yes.
If not on.
Unplug the unit.
If the heater is OK
#5 Posted : Tuesday, June 7, 2011 12:36:41 AM(UTC)
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
Guest (5)
