I have a Frigidaire dishwasher that is not drying the dishes. It finishes the complete cycle but the dishes are still wet. Any help is appreciated.
Remove the kick plate Remove one wire from the heating element and measure it for continuity. You may also have one or two thermostats under the unit they most likely should be 0 ohms. |
THIS FORUM IS DEAD!!!!!!! |
