Need help with this problem...The normal cycle stars and is completed. The dishwasher then starts the normal cycle on its own...no buttons presed. To stop the cycle I press the cancel button the unit will stop and the lock light blinks. If I open and close the front door the unit will start in normal cycle on its own. operation panel or control board?
Seems like a shorted key pad. No way to test, just order a new one.
