jrgaytan
#1 Posted : Friday, August 1, 2008 1:02:26 PM(UTC)
jrgaytan
The display in my 2.5 year-old double oven went blank. I can turn the lights and fans on but I cannot read anything in the screen (not even the clock). I tried resetting, cleaning connectors and any suggestion posted on the web.
My conclusion is that I will have to replace parts... My question is: should I replace the control panel (P/N 8302319) or the display component ( P/N 8300435)? or both? Is there any way to know for sure where is the problem?
Thank you
jcichy
#2 Posted : Saturday, November 22, 2008 9:00:22 AM(UTC)
jcichy
I have the same problem. Did you have to replace both parts. The control panel is tough to get, and backordered, so I guess this is at least part of the problem.
jrgaytan
#3 Posted : Saturday, November 22, 2008 11:16:08 AM(UTC)
jrgaytan
I ordered both parts just to be safe. Unfortunately I received the wrong display and the control panel, as you said, is backordered. As soon as I receive it and solve the problem I will post my results here. Hopefuly it will save you some $$ or time (if the control panel ever arrives)
oceanmann1
#4 Posted : Wednesday, February 25, 2009 8:33:39 AM(UTC)
oceanmann1
Hi.
I have the same problem with our double oven.
What was your solution?
Thanks.
Dan
jrgaytan
#5 Posted : Wednesday, February 25, 2009 10:49:15 AM(UTC)
jrgaytan
I ordered and replaced both parts and the oven is working now. Just be patient since the control panel took a while to arrive (7 weeks!)
Needless to say... this was not an economical solution. Ended up spending around $300 for both parts.
Tom Stockton
#6 Posted : Friday, March 26, 2010 8:00:55 AM(UTC)
Tom Stockton
What was the fix?
Tom Stockton
#7 Posted : Friday, March 26, 2010 8:02:37 AM(UTC)
Tom Stockton
Originally Posted by: oceanmann1 Go to Quoted Post
Hi.
Thanks.
Dan
I have the same problem. Did you get it fixed?
Ryandeen
#8 Posted : Tuesday, January 29, 2013 5:46:33 PM(UTC)
Ryandeen
I have the same problem and someone told me it might be the transformer.
