KWVB
#1 Posted : Friday, June 3, 2011 7:13:07 PM(UTC)
KWVB
Views messages in topic : 1
side by side, frig and freezer not cooling, opened the back, fan is not working, don't hear anything else on (like the compressor), the lights work though, and i vacumed all the dust out, what could be the problem?
#2 Posted : Saturday, June 4, 2011 4:53:56 AM(UTC)
Are you sure it is not a ED22TWXDW02?
I could not find any info on the given model number but did find the above.
Here are the parts for the unit I could find.
Replacement parts for WHIRLPOOL ED22TWXDW02 REFRIGERATORS | AppliancePartsPros.com
Sounds like you may be stuck in a defrost cycle.
The compressor, the condenser/compressor fan and the evaporator fan all will be off.
Try forcing it out of defrost by turning the defrost timer (Item 6 in Section 11) cam with a screw driver. It only can be turned one direction also there is usually a hole in the control cover to let you do this.
If the unit fires up you need a new timer.
