hardwaremonkey
#1 Posted : Friday, November 21, 2008 8:29:57 PM(UTC)
hardwaremonkey
Our washer does not know warm. Have it run hot, and it is HOT. Have it on cold and it is COLD. Have it on warm and it is HOT.
When under warranty, a guy replaced the water temp switch. It seemed to help some, but it still was not quite right.
I can use a multi-meter. I have a diagram. I have torn the thing apart and know how to get at everything. But, I am not certain what I am looking for or what to test. I am guessing the the water valve is messed up, or a thermostat. I see on the diagram a temp control light, but I have NO idea where that light might be.
Can you help get me started?
Thanks!!
hardwaremonkey
#2 Posted : Saturday, November 22, 2008 6:28:51 AM(UTC)
hardwaremonkey
I forgot to mention that when you start the washer on warm, it actually comes out warm at first. Then, something in the automatic temperature control system goes haywire and it turns to FULL HOT.
Does that help any?
libertyappl
#3 Posted : Saturday, November 22, 2008 6:59:59 AM(UTC)
libertyappl
I would test the water temp selector switch, part Switch, wash opt (4 pos.Wht)
Nat
hardwaremonkey
#4 Posted : Saturday, November 22, 2008 8:15:38 AM(UTC)
hardwaremonkey
Test it how, for what? I assume an ohm reading, right?
libertyappl
#5 Posted : Saturday, November 22, 2008 8:20:05 AM(UTC)
libertyappl
Yes see if it ohms out.
Nat
Guest (7)
