I had my hard wood floors replaced and when they reconnected the stove back the oven works and now the burners click but won't ignite. Does the gas line have to be primed or what needs to be done to get the burners to light?
Does the gas come out of the top burners?
No, there is no gas coming out of the top burners.
Make sure the gas shut off valve behind the range is completely open. Turn on any gas burner valve and keep it open for 15-20 seconds to let the gas push out the air from the tubes.
