dont have the model number heres whats going on the oven burner sputters or the flames are jumping then they go down if you turn on the top burner the flames remain constant soon as you turn off the top burner the flame goes inconsistent. coul you please tell me what i could do
You will need to locate the model number it's on the range. It sounds kind of like a regulator/valve problem.
Nat
