Topnotch
#1 Posted : Thursday, June 2, 2011 3:14:35 PM(UTC)
Topnotch
The oven element nor the broiler element will come on when the control knob is activated. However, the light, timer, etc. will. Any ideas on what the problem is?
#2 Posted : Friday, June 3, 2011 4:10:01 AM(UTC)
Use "POST REPLY" not "POST NEW TOPIC" as post new topic is not linked to your original post so it gets very confusing.
Here are your parts includes a wiring diagram.
Replacement parts for MAGIC CHEF 9512WUV WALLOVEN- STD ELE | AppliancePartsPros.com
The light, timer use 120 volts (half the line) while the heating elements requite the full 240.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If power is OK then check the current paths with a meter using resistance.
Be sure to remove power from the unit when doing this.
To make tracing the circuits easier, print out a couple wiring diagrams and mak the circuit paths to the elements using colored pencils.
Magic Chef Oven Problem (Oven Repair (including Ranges and Cooktops))
by Topnotch 6/2/2011 3:18:53 PM(UTC)
Magic Chef oven problem (Oven Repair (including Ranges and Cooktops))
by jszczupak 6/14/2010 12:18:18 PM(UTC)
