patty61
#1 Posted : 16 years ago
patty61
I'm having a problem with the right front burner on my GE profile cooktop. I can't adjust the temperature, it stays on high all the time. Is this an easy fix? Thansgiving is a week away and I'm FREAKING OUT!!!!
libertyappl
#2 Posted : 16 years ago
libertyappl
Can you double check your model number that comes up as a refrigerator.
Nat
patty61
#3 Posted : 16 years ago
patty61
How about JP360.
libertyappl
#4 Posted : 16 years ago
libertyappl
The dual element switch is part # AP2023824
The Halogen element switch is AP2023825
It's does say which is which on the breakdown.
Hope that helps you a little.
Nat
patty61
#5 Posted : 16 years ago
patty61
Is this a GE part #? I checked their website and they do not recognize that part #
libertyappl
#6 Posted : 16 years ago
libertyappl
No those are the part number from this site, which will be cheaper than from the GE website.
Nat
libertyappl
#7 Posted : 16 years ago
libertyappl
Patti61,
click on this link and it will take you to the dual switch mentioned in the other post Part Details - GE Switch, infinite heat, part number: AP2023824
Nat
patty61
#8 Posted : 16 years ago
patty61
Nat,
Thanks so much for your help. This is great. I'll order the part ASAP.
Thanks again,
Pat
