edsteed
#1 Posted : Tuesday, May 31, 2011 12:08:43 PM(UTC)
edsteed
No lights on panel and DW is inoperative.
Reset circuit breaker to DW and (normal wash) and (heated dry) lights come on but DW will not operate.
Lights go off after two minutes and no lights remain on
Thanks for any help,
Ed
#2 Posted : Tuesday, May 31, 2011 4:06:26 PM(UTC)
Ed,
You may want to start the troubleshooting from the door interlock switches (#803 on the diagram).
- The door interlock switch Part number: AP3872949
edsteed
#3 Posted : Tuesday, May 31, 2011 4:15:15 PM(UTC)
edsteed
Thanks Gene. I am going to check the switches before I order a board.
#4 Posted : Wednesday, June 1, 2011 1:12:16 PM(UTC)
You are welcome Ed. Keep us posted.
edsteed
#5 Posted : Thursday, June 2, 2011 8:48:15 AM(UTC)
edsteed
Greg,
The problem is the Interlock Door, Part 1003. The mounting tabs are broken off losing the plunger and spring which would not allow the switches to actuate.
Thanks,
Ed
UserPostedImage
#6 Posted : Thursday, June 2, 2011 4:29:33 PM(UTC)
Ed,
I'm glad you found the problem. Thank you for the feed back.
