Installed a new circuit board and clock. The cook top works fine but when we try to use the oven we get the "F1:E3" code. The code definition is "Wiring harness cavity size does not match previously stored value." There is a black jumper wire on the circuit board but I'm not sure if it is the right one. Any help would be appreciated.:(
That code means... The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Nat
Thank you for your response. When the jumper is connected to the circuit board the code appears when the oven is started, and it does not heat up. When the jumper is removed the code does not appear. However, when I input the temperature for the oven to bake at the display reads "Start?". When I enter "Start" nothing happens for a few seconds then "Start?" comes up again. Is it possible that there are sensors or a fuse that need to be replaced?
What is the part number you installed?
Nat
The part was purchased through Repair Clinic and the item number is 941484. Circuit board / clock. I transferred the jump wire from the old circuit board to the new one.
Did that work?
I can't see the actual part number only their part number. nat
Thank you for your efforts. I'll get the part number when I get home tonight.
Here is the part number IMP 1233782. I went through the programming sequence and at the next to the last entry (Press "Start") the display is supposed to show ELE and also show a product description of hb - Sl (Hidden Bake Slide-In units). The display remains blank. This happens when the jumper is installed or removed. Thank you for your assistance.
Joe:confused:
