2 Pages12>
jojersey
#1 Posted : Tuesday, November 18, 2008 8:25:51 AM(UTC)
jojersey
Help, Bosch dishwasher, maybe 15 minutes into wash I heard a POP, then white and black smoke came out from top... I shut it down, I wasn't sure if it was on fire... but the only thing that lingered was the smoke smell. Could it be the motor and electric module? How do you get into washer to see the parts?
thanks Jo:(
libertyappl
#2 Posted : Tuesday, November 18, 2008 9:00:50 AM(UTC)
libertyappl
NOt sure which of these is your unit, but the breakdowns should help you get into it.
1.) Model SHU3302 UC/12 (FD 8003 -)
2.) Model SHU3302 UC/06 (FD 7902-8003)
3.) Model SHU3302 UC/11 (FD 8003-8003)
Nat
jojersey
#3 Posted : Tuesday, November 18, 2008 11:09:42 AM(UTC)
jojersey
Nat
Thanks does it sound like the motor, or something else?
JO
libertyappl
#4 Posted : Tuesday, November 18, 2008 11:23:50 AM(UTC)
libertyappl
I would say the motor, but that's just a guess because we don't work on Bosch.
Nat
jlgx4
#5 Posted : Thursday, November 20, 2008 6:51:26 PM(UTC)
jlgx4
Jojersy, we're u able to diag. your washer? Today my Bosch did almost the same thing. two pops and now totally dead, no power no lite?
Thanks,
jlgx4
jojersey
#6 Posted : Monday, November 24, 2008 8:24:13 AM(UTC)
jojersey
Thanks,
From all I read this happens to Bosch dishwashers... The control module seems to need replacing, I'm just worried that it may happen again and start fire? I wrote Bosch, but I don't know If I get a answer.
thanks JO
Sluing14
#7 Posted : Saturday, December 6, 2008 4:23:53 PM(UTC)
Sluing14
I had the very same thing happen on Halloween. Same model, same timing. After removing the door and the facia it was obvious by the burn marks that it was the control module. The original module replaced was part number 268198 which was replaced by 491870. I also replaced the soap dispenser as it would no longer close. The module was easy to replace but about $150. The first part I rec'd appeared used so I called and rec'd a replacement. The replacement part included "re-programming" instructions which were not sent with the first. The only problem is that the code required doesn't appear. I have called Bosch (very unresponsive) and APP (who suggested I post as they couldn't help). They sent another replacement (with no re-programmimg instructions this time). The DW works but the soap dispenser will not open. I have posted here and have not seen a response. I wish I would have just replaced the DW.
PRYGAARD
#8 Posted : Monday, December 15, 2008 6:23:38 PM(UTC)
PRYGAARD
I had the exact same symptom on my BOSCH SHU3336UC/U12. :(. My wife went to the parts store and they sold her a '491870' controller.... buy no one said anything about programming it. I am about to put the part into the dishwasher but now I wonder if I should wait...... Have you heard back on the programing?
JAN 25 '09 UPDATE: BOSCH ISSUED A PRODUCT RECALL ON THIS!!
I just got a recall notice from Bosch on this problem!! The letter describes it as:
"Bosch has found that an electrical component in the dishwasher's control panel can overheat and potentially catch fire. In some cases, the dishwasher fire has caused damage to surrounding cabinet walls and counter tops. No injuries have been reported "
The full Letter is attached below.
The impacted model numbers must begin with:
SHE43C, SHE44C
SHE46C, SHE56C
SHU33
SHU42
SHU432
SHU43C, SHU53C
If you have one of these you should probably call them at 800-856-9226.
The letter offers to send a repairman to replace the part. I called and told them I had the part smoke/burn on me and already replaced it. It looks like I am going to be refunded the price of the part.
UPDATE: 1/28/09: I just got a call from Bosch. The new part: 491870 is ALSO under recall. They asked me not to use the DW and want to send a repairman out. So... if you have replaced your controller with a '491870'...you still need to follow up with Bosch and get it replaced.
Cheers
File Attachment(s):
Bosch Recall.doc (1,386kb) downloaded 55 time(s).
#9 Posted : Tuesday, December 16, 2008 4:11:11 PM(UTC)
Guys,
As far as I know the replacement control board for Bosch dishwasher does not need any programming. The only important thing is if there is a jumper wire on the old board then this wire has to be moved to the new board.
PRYGAARD
#10 Posted : Tuesday, December 16, 2008 6:01:45 PM(UTC)
PRYGAARD
Thanks Gene!
I did not see a jumper on the old board...
I tried to program the 491870 board but just like others, I could not get the right code (The instructions said I needed a zero code)
BTW: The instructions for the 491870 are posted at:
http://www.servicetechhelp.com/...structions/BSH491870.pdf
So.... I installed it. It seems to be working (including the soap dispenser)
I will keep checking back to see if anyone has learned anything more.
thanks everyone for the help! :)
2 Pages12>
