SueMooney
#1 Posted : Thursday, November 20, 2008 4:03:32 PM(UTC)
SueMooney
I have this spacesaver washing maching and it won't drain all the way, there fore it won't start spinning to ring out the water in the clothes, I have had pump problems, is that my problem again, The pump was repaired or replaced, don't know which they did when it was fixed
libertyappl
#2 Posted : Thursday, November 20, 2008 4:07:35 PM(UTC)
libertyappl
Most likely something stuck inside the pump if it's draining partially.
Here's the breakdown Model WSLP1100A0WW
Nat
