aburns24
#1 Posted : Tuesday, August 5, 2008 8:41:05 AM(UTC)
aburns24
I have a kenmore gas free standing range. The stove and broiler light but not the oven. I do not smell gas and can not manually light the oven when the dial is set to oven. Is this a selector dial problem?
abadfish66
#2 Posted : Tuesday, August 5, 2008 8:58:08 AM(UTC)
abadfish66
Most likely a bad bake glowbar, measure resistance of the glowbar, should be between 50-150ohms, if not replace.
tscs4951
#3 Posted : Thursday, November 20, 2008 3:48:26 PM(UTC)
tscs4951
i have a kenmore gas range , has top broiler and lower burner. The broiler works but the lower burner will not lite .The glo-bar heats up but the burner will not ignite.could the glo-bar be defective even though it heats up.please help.
