fixit318
#1 Posted : Thursday, November 20, 2008 2:46:24 PM(UTC)
fixit318
I can hear the timer on my dryer ticking but I can't get it to run. :confused: I also hear a low humming near the power button. HELP!!! I cleaned out the hose in the back. What else can I do?
libertyappl
#2 Posted : Thursday, November 20, 2008 3:09:59 PM(UTC)
libertyappl
Check your door switch with an ohm meter, check it for continuity.
here's your parts breakdown Model REX4625EW2
Nat
fixit318
#3 Posted : Thursday, November 20, 2008 3:23:59 PM(UTC)
fixit318
Whats a ohm meter? I held the door switch down and pressed the on button at the same time and nothing is working but the timer.
libertyappl
#4 Posted : Thursday, November 20, 2008 3:28:45 PM(UTC)
libertyappl
Without the appropriate tools you'll probably need to call in a technician.
Nat
#5 Posted : Thursday, November 20, 2008 10:29:06 PM(UTC)
Go to this site to learn the basics
http://www.applianceaid.com/dryers.html
There is a good sticky at the top of this forum"How to check dryer parts for continuity".
Click on the Model Number in your post to see the parts breakdown
If you open up the console, be careful 240 volts can kill, so unplug the unit when working on it.
Try different settings timed dry and temps etc. you may be able to get more symptoms to help troubleshoot.
Here is your wiring diagram
https://www.servicematters.com/d...0Sheet%20-%203401728.pdf
Guest (4)
