atlanta handyman
#1 Posted : Thursday, November 20, 2008 2:20:38 PM(UTC)
atlanta handyman
I have a frigidaire FSE747GES0 that is making a slight squealing noise when it is running?
I have to mamualy start the drum to spin and it will run for about 40% of the time then it will stop and then I will have to restart it?
What do i need? Rear bearing and maybe the motor
When replacing the Rear bearing and or motor what other parts should be replaced while I have it apart? This is for perventive measures.
Where can I get a repair manual for this model?
How do you take the covers off to replace the parts?
libertyappl
#2 Posted : Thursday, November 20, 2008 2:24:11 PM(UTC)
libertyappl
The bearing in the back is probably shot and it's causing a strain on the motor and it's over heating, then shutting down.
Here's the breakdown Model FSE747GES0
Nat
kayakcrzy
#3 Posted : Thursday, November 20, 2008 5:21:02 PM(UTC)
kayakcrzy
You probably have a clogged vent to the outside, and have a bad motor, and need to replace the rear bearing. I would replace the dryer. But before you do, chech the vent to the outside. Tom ApplianceEducator.com
Guest (4)
Frigidaire Electric Dryer - All Lights Are Flashing (Dryer Repair)
by Guest 4/15/2021 8:50:11 AM(UTC)
Frigidaire electric dryer (Dryer Repair)
by n.mcphee 6/14/2018 6:55:43 AM(UTC)
Frigidaire electric dryer stop advancing (Dryer Repair)
by blueking 9/13/2014 4:38:26 PM(UTC)
Frigidaire Electric Dryer (Dryer Repair)
by Menotu 6/2/2014 4:28:45 AM(UTC)
Frigidaire electric dryer, no heat (Dryer Repair)
by stevedill 4/15/2013 4:01:56 PM(UTC)
Frigidaire electric dryer belt replacement (Dryer Repair)
by award 6/21/2010 11:14:23 AM(UTC)
Frigidaire Electric Dryer - Blinking Lights (Dryer Repair)
by gin4sing 1/4/2010 10:32:04 AM(UTC)
frigidaire electric dryer (Dryer Repair)
by GaydosBlessed 6/25/2009 5:38:02 AM(UTC)
by cafero99 5/24/2009 4:00:11 PM(UTC)
Need help replacing heating element coil in Frigidaire electric dryer (Dryer Repair)
by JeffJ 4/27/2009 4:22:44 AM(UTC)
Frigidaire Electric Dryer Not Heating (Dryer Repair)
by tleelee 1/22/2009 7:13:52 AM(UTC)
Frigidaire Electric dryer Hums and timer clicks (Dryer Repair)
by ButchL 1/18/2009 11:34:16 AM(UTC)
by outlaw 1/19/2008 5:43:16 AM(UTC)
