My glass top drop in magic chef model # 58hk 6txw, serial # 16c139761596 broiler nor oven is heating. When placed to desired temp, you can hear the oven turn on, but no heat is coming out.
Remove the back off of your range and look for a broken/chewed wire. Make sure you unplug it before doing anything though.
Nat
I have already inspected the wiring and see no damages to the wiring on the oven. :confused:
Can you post your wiring diagram?
Nat
