brummel
#1 Posted : 16 years ago
brummel
Problem started with F1 error code and replaced the control board at $300
Once replaced thenI was getting error code F2 E1. Went and checked connections again on the cable connector and other things such as transfer voltages etc. everything looked good. Also some the the keys did work but not all, such as turning the light on in the oven.
So I replaced the control Panel at $260. Although the cable has different numbers your parts said it was a replacement part and it was OK. What I get now is that the switches work but they do not control what they are supposed to control. And when I turn power on initially the top oven is locked in the clean mode then I get the F2 E1 error code again. The documentation I got with the oven says there is a cancel switch with the OFF oven button does this reset the control board? What is this thing doing? Help? Help?
Ed
v2k04
#2 Posted : 16 years ago
v2k04
try pushing the start and hold it for 5 seconds or try the same with the cancel push and hold
brummel
#3 Posted : 16 years ago
brummel
Tried what you suggested but it still does not work but here is some more info.
Turn power on = The PF and the clock with correct time comes on. The top oven door is locked. (When power is off door opens)
Depress 'Start' PB for 5 secs= The PF goes off the button beeps 3 times.
Depress Upper Oven PB = Get 1 beep, no change (NC)
Depress Lower Oven PB = Get 1 beep, NC
Depress UpTemp PB = 3 beeps, NC
Depress LoTemp PB = 1 beep, then I get a 'Timer' light indication.
Depress Upper Oven OFF PB = goes into the Convection Bake @ 325'
Depress Upper Oven PB = Starts increasing the temperature display.
Hope this helps in diagnosing the problem. Thanks for all of your help.
Ed
brummel
#4 Posted : 16 years ago
brummel
If anyone has suggestions on this problem would love to hear them. Thanks
brummel
#5 Posted : 16 years ago
brummel
Anything new on what the problem is? If anyone can help would sure appreciate any help.
Ed
Error Codes on lg dishwasher LDF5545st (Dishwasher Repair)
by Guest 2 years ago
Does anyone know how to clear error codes on Bosch Washer (Washer Repair)
by bmoney37 5 years ago
Getting error codes On Maytag Meptune FL (Washer Repair)
by TUFFTJ 10 years ago
