Scotty
#1 Posted : Monday, October 22, 2007 12:00:15 PM(UTC)
Scotty
We have had this washer for a period of about 4 years or more and have had nothing but trouble. They have changed one unit right after another.
What it is doing is when you set it to wash and rinse cold it will run cold sometimes for wash but will run hot on rinse and vice versa. We have changed hoses and have set it to run in reverse such as if you want cold set it to hot in which works sometimes. Also on the detergent dispenser it quit working and I have cleaned it with no success. I have heard that there is a valve that goes bad
#2 Posted : Monday, October 22, 2007 3:29:46 PM(UTC)
Hi Scotty
Your washer (including all water valves) operates by the main control board. Most likely the problem is there and it has to be replaced.
- The part number for the new main control board AP3672586
- Here are the break down diagrams for the Maytag Neptune washer Model MAH5500BWW
Good luck.
