Hi-- I have replaced a damaged accumulator assembly in this dishwasher, so when dishes weren't clean, I took it apart to see if it was operating fine. It was. I have been cleaning the system with a vinegar soak regularly. It seems like the top dishes come out greasier, and less clean than the bottom. (WHich aren't that clean) Any suggestions? I checked all the water outlets, and the top one seems to be a bit corroded but I cleaned it and it didn't seem to help. THANKS
Groups ready for retrieval: Senior Expert
I cannot find any info on the given model number, please check it.
A greasy film sounds like the water is not hot enough. Check that it at least 120 degrees F when entering the unit. Check that the heating element is working.
Since you have checked your pump/filters there is a possibility that you have a fill problem. Most units fill to just under the heating coil. This can be checked by adding a couple quarts of hot water after each fill during a cycle. If it now washes OK then check the fill valve. Just be careful to not overfill it. Often if the fill is low you will also hear a growling sound because the pump will cavitate (suck in air). The most common cause is a dirty screen filter on the input side of the fill calve. Remove the valve from the unit and clean/check the filter. Do not permanently remove it from the valve as it is there to keep crud out of the valve which could hold it open and cause a flood.
If it still does not fill correctly I would replace the fill valve. |
THIS FORUM IS DEAD!!!!!!! |
Ok-- It seems to be filling fine but will check the valve to be sure. The coil seems to be a bit corroded so maybe it is the heat issue. Checked the model number again, it seems to be correct, maybe the B is an 8? KUDPO2CRBSO
