oven works, boiler has pilot light and it burns good. Broiler won't burn appears not to turn on gas to broiler.
I'm afraid I did not get it clear, but if there is a glow coil igniter (round type) then this part is no longer available.
no glow device. there is a polit lite and it is burning all time. oven burner works fine. Just broiler won't burn
The model number you posted does not come up and I can not get right information for this model. If you can post a pictures of the pilot, the gas valve and the oven thermostat, it might help for proper diagnosis.
