Our washer will do everything but go through the spin cycle. We ran a test and got error (message 47...Board thinks the door PTC circuit is open in spin.) It said to remove the door lock assembly and measure the rsistance of the PTC. It says: shorted or open. defective door lock assembly.Reads arounds 1500 OHMS. Defective control board. We took the door lock assembly out and it read 1484. So could some help me to understand which is part is bad? Thanks for all the help!
Originally Posted by: tburrows  ...It says: 1. shorted or open. defective door lock assembly.
2. Reads around 1500 OHMS. Defective control board.
We took the door lock assembly out and it read 1484... "Shorted" means 0 Ohms, "open" means ∞ Ohms. Your test result is 1484 Ohms which is very close to 1500 Ohms. According to this instructions there is defective control board. - The part number for the control board is AP4354654 Here are the break down diagrams for the Frigidaire washer Model FTF2140ES0Gene.
