TexasTaylors
#1 Posted : Saturday, May 28, 2011 8:18:42 PM(UTC)
TexasTaylors
Our Maytag washer is only a few years old, but I don't know the model number. Top load, has worked well for years. Recently the washer has started to push water above the inner drum during the wash/agitate cycle. Only happens when we do large or super-size loads. No leaks during fill/drain. I took front off and watch, no leaking from drum, hoses, seals, etc. When it's in the wash cycle with a pretty full load, after a while the clothes start to ride up the sides of the inner drum and eventually water gets pushed up over the top of the drum. I didn't use to do this. Any suggestions?
TexasTaylors
#2 Posted : Sunday, May 29, 2011 2:07:24 AM(UTC)
TexasTaylors
Also - I've just never paid attention to this before....but should the inner drum be rotating during the agitation cycle? It's spinning pretty fast (not as fast as the rinse cycle). I wonder if that's somehow helping the clothes "build up" along the sides of the drum and pushing the water up over the edge of the drum.
TexasTaylors
#3 Posted : Monday, May 30, 2011 5:43:45 AM(UTC)
TexasTaylors
Any suggestions out there from the peanut gallery?
