dugclark
#1 Posted : Friday, October 19, 2007 6:14:50 PM(UTC)
dugclark
I replaced the timer a month ago and the dryer will not shut off. Is the timer bad?
#2 Posted : Saturday, October 20, 2007 1:34:06 AM(UTC)
Does the timed cycle work and time out? If not, your little timer motor is blown out=new timer time.
dugclark
#3 Posted : Sunday, October 21, 2007 7:04:40 AM(UTC)
dugclark
Do i need to order a new timer again? I replaced the old one a couple of months ago, but it still won't cycle off. The dial just sits there and the dryer will run till I turn it off.
#4 Posted : Monday, October 22, 2007 1:15:20 AM(UTC)
Measure the resistance of your timer motor, it should be around 1,000 ohms, if open, you will need to replace it or the whole timer.
