clasyglfer
#1 Posted : Tuesday, November 18, 2008 4:23:46 PM(UTC)
clasyglfer
Two things: when it spins makes a very loud noise..think it's going to "take off"
The second item: was doing some laundry and noticed that sheet got caught under the agitator(the white cone in the middle of the tub) I can't seem to get the sheet free. Help.
thanks!
libertyappl
#2 Posted : Tuesday, November 18, 2008 5:18:13 PM(UTC)
libertyappl
To start with remove the cap on top and the bolt underneath the cap to lift the agitator out (you'll probably have to pull hard)
Here's the breakdown Model LWD70AW
Then we can go from there.
Nat
clasyglfer
#3 Posted : Tuesday, November 18, 2008 6:45:02 PM(UTC)
clasyglfer
Thanks Nat..got the agitator released and pulled the fitted sheet out. OK..so what about that "spinning" noise that sounds like it's ready for "take off"?
libertyappl
#4 Posted : Wednesday, November 19, 2008 5:28:46 AM(UTC)
libertyappl
When it's spinning is is a knocking noise or like a whirling noise?
If it's a loud whirlig noise use a flashlight and look in each of the whole inside the tube for something stuck thru to the outter tub. Let me know what you find and I'll take a look at the breakdown again.
Nat
