AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
will replace belt & tensioner.... what else???
I would check all the items you listed for wear / slop. If OK I would not replace them. A drop of oil on the roller shafts will not hurt but just a drop as oil collects lint. Also the front glides/drum support.
Also clean and check your vent system. |
THIS FORUM IS DEAD!!!!!!! |
Thank you Denman, will do
OOPS! Just reread my post to you and noticed the way I added the sentence about the front glides could be interpreted that i am recommending putting oil on these. I am NOT recommending oiling these.
The glides should just be checked for wear and replaced if necessary.
They jumped into my mind at the end of my reply so I just jotted down a sentence. I better start paying more attention when I read my reply's before posting. Sorry if this caused any confusion. |
Originally Posted by: denman  OOPS! Just reread my post to you and noticed the way I added the sentence about the front glides could be interpreted that i am recommending putting oil on these. I am NOT recommending oiling these.
Thanks Denman, I didn't take it that way, I realize you meant to lightly lube the rollers at the shaft only. Haven't bought the parts and fixed it yet... will post when done. Thanks again for your advice
Dryer Repair
