2 Pages12>
Ron6519
#1 Posted : Thursday, May 26, 2011 1:06:05 PM(UTC)
Ron6519
I need to replace the hinges and the receptors on both doors. The parts listings show 2 different hinges and 2 different receptors. How do I know which part is correct?
Thanks.
Model is JJW9630DDB.
Ron
Joe / APP Team
#2 Posted : Thursday, May 26, 2011 1:23:22 PM(UTC)
Joe / APP Team
Thanks.
Ron
Ron the series number ( the first 2 numbers of the serial number)will determine which part to order/replace.
If you can re post the model and the serial number, we'd be happy to do the research the parts for you.
Ron6519
#3 Posted : Thursday, May 26, 2011 1:25:29 PM(UTC)
Ron6519
Thanks. I'll have to get to it after the oven is off.
Ron
Joe / APP Team
#4 Posted : Friday, May 27, 2011 5:02:37 AM(UTC)
Joe / APP Team
Ron
Ron,
Not a problem, We'll keep an eye out for your next post.
Ron6519
#5 Posted : Friday, May 27, 2011 9:54:00 AM(UTC)
Ron6519
Joe, this just gets better. I made out the first 3 characters as "115" and the rest were grease covered. I took a sponge with soap to clean off the grease and it wiped out the serial number completely.
Is there another place the serial # would be?
I bought the ovens in about 2004.
Ron
Joe / APP Team
#6 Posted : Friday, May 27, 2011 1:05:37 PM(UTC)
Joe / APP Team
Ron
Ron,
Sorry, but no, there is not a hidden model/serial tag.
So at this point you have a J/A double wall oven, model number JJW9630ddb series 11. (you may want to keep that handy for future reference.
With that, you will need to order at least one hinge/receptacle kit( you have the same hinges/receptacle on both doors),
Part number: AP4009190
After you install the kit, put the oven in a 4 hour self clean cycle, you'll be a lot more happy with the results.
Good Luck,
Ron6519
#7 Posted : Saturday, May 28, 2011 11:14:15 AM(UTC)
Ron6519
Joe, a couple of more questions.
Does the kit contain 2 hinges and 2 receivers. Enough to do one door?
AND
Are these kits an upgraded set of hardware, as the original set was not up to the task of holding the doors shut. I don't want another under engineered hinge set.
Thanks.
Ron
Joe / APP Team
#8 Posted : Tuesday, May 31, 2011 6:59:34 AM(UTC)
Joe / APP Team
AND
Thanks.
Ron
Ron,
Yes on both counts, the hinges and receivers are re-engineered for longevity and a more "positive" closing action.
The "kit" will contain everything you need to repair 1(one) door assembly.
The 4 hour self clean cycle, has been a "unwritten" rule of thumb, on J/A products for 30 + years, that I know of.
You'll be fine,
Good Luck,
Ron6519
#9 Posted : Tuesday, May 31, 2011 7:02:36 AM(UTC)
Ron6519
Thanks for the information.
Ron
Joe / APP Team
#10 Posted : Tuesday, May 31, 2011 7:55:36 AM(UTC)
Joe / APP Team
Ron
Ron,
You're welcome,
You'll do fine.
:cool: :cool: :cool:
Guest (10)
2 Pages12>
