berry3692
#1 Posted : Tuesday, November 18, 2008 6:37:43 AM(UTC)
berry3692
I m ordering parts for the glass part of the door. the two inner glass pieces. and the middle glass and the gasket.
1. Should I order the outside glass to protect its integrity?
2. Do I need some type of sealant other than the gasket for installation?
3. Can I use the oven with this crack on the inside glass if the other glass is no damaged?
libertyappl
#2 Posted : Tuesday, November 18, 2008 7:17:29 AM(UTC)
libertyappl
I wouldn't use the oven, the inner glass is a heat barrier. If it is only the inner glass that is cracked you shouldn't have to order all the others. Part #AP375195
Nat
berry3692
#3 Posted : Tuesday, November 18, 2008 8:05:42 AM(UTC)
berry3692
Thank you for your quick reply. I did turn the oven on and noted heavy condensation inbetween the inner and on the middle glass.. I immediatly turned it off. No baking on my day off.
I did order two pieces of glass AP375195 & AP373925 with the gasket AP371039. I thought if the integrity of the heat barrier was broken it must be a leak in the gasket? Also how does this glass retainer AP374940 work?
Worse case I will return the parts.
