2 Pages12>
pattyman
#1 Posted : 18 years ago
pattyman
Hello,
I plan on purchasing a new washer and dryer. My old dryer has the 3 prong outlet. From what I understand, the newer models have 4 prongs. My question is this: "Do I need to replace the wire that runs from my breaker box to the outlet, or, will I just be replacing the outlet?"
Thanks...
ApplianceJunk
#2 Posted : 18 years ago
ApplianceJunk
New dryers do not come with a cord.
You will have to buy a new cord or remove the cord from your old dryer and install in on your new dryer.
If the cord is old you maybe best to spend the money on a new three wire dryer cord.
No need to do either one. :)
pattyman
#3 Posted : 18 years ago
pattyman
So, is it best to use the 4 prong?? Can a 3 prong be used on a newer model?? Can I use the same wire that runs from the outlet to the breaker box??
Thanks.:confused:
ApplianceJunk
#4 Posted : 18 years ago
ApplianceJunk
Yes, take the three wire cord off of the old dryer and put in on the new dryer.
Your new dryer will not come with a cord.
You should not have to do anything with the wire that runs to the breaker box.
You do have a cord on your dryer now, correct?
The dryer is not hard wired to the breaker box.
ApplianceJunk
#5 Posted : 18 years ago
ApplianceJunk
Not really better, just a change in electrical code in the homes.
New homes are wired with 4 wire outlet for the dryer.
Just a extra ground wire on the four wire ones.
pattyman
#6 Posted : 18 years ago
pattyman
yes i do have a cord...3 prong. So, just use that one for the new dryer??
ApplianceJunk
#7 Posted : 18 years ago
ApplianceJunk
Yes, if it looks ok. No burnt ends or cracked insulation.
If it looks bad just buy a new three prong cord to put on the new dryer.
What brand of washer and dryer did you buy?
#8 Posted : 18 years ago
Your new dryer may come with a isolated frame ground, ie, power ground not shorted to the frame.
If you just wire it up with a three prong pigtail, you will have no protection from an internal short, ie, you just might get a dangerous shock!!
For safety reasons,it's best to use the four prong pigtail. New dryers have wiring instructions for this printed on the back panel.
The 4 wire pigtails protect you in case of a lightning strike by grounding the frame to solid earth ground at a water pipe and routing the power ground to the power ground connection at the fuse box. One thousand amps running through ground during a lightning strike will elevate your dryer frame to 1000 volts, assuming one ohm resistance!!The four wire pigtail will prevent this.
To do this, you will need to rout a new dryer cord from the dryer wall outlet, to the fuse box.
ApplianceJunk
#9 Posted : 18 years ago
ApplianceJunk
What!?, a new dryer without a ground to the frame?
That would be a first for me and I have been putting dryer cords on for over 20 years. If the dryer is new I don't believe it would come without a grounded frame.
If the dryer is used then you would need to check to make sure.
What brand of dryer does not come with a grounded frame? Not Whirlpool, Frigidaire, Maytag or LG.
pattyman,
If you unsure just ask the place you are getting the appliances from to install a new three wire dryer corder on your new dryer for you. It should take them all of two minutes to do that for you.
#10 Posted : 18 years ago
If the dryer had a 4 wire pigtail installed, the frame would not be connected to the power ground.
But you are all ignoring the first question, is it better to have a 4 wire pigtail and I said yes, for safety reasons. It is ALWAYS best to tell anyone what is best and WHY.
Sure in many cases I run across a 3 wire pigtail and the customer deals with it rather than spend the extra money for a 4 wire connection to the fusebox.
2 Pages12>
