Glenvan
#1 Posted : Monday, November 17, 2008 7:12:06 PM(UTC)
Glenvan
The dishwasher completed the clean cycle but water is left in the bottom. The entire control panel is off, no blinking lights or anything. There is power to the outlet that the dishwasher is plugged into. The machine is probably less than a year old. Any advice would be appreciated.
#2 Posted : Monday, November 17, 2008 8:35:33 PM(UTC)
Most common cause is a plugged or partially plugged drain hose or drain.
Often at the fitting where it attaches to the sink, there is a lip here so it can hold junk back.
Also your Model Number appears to be short a few characters. Should have 4 letters and a numeral at the end.
Glenvan
#3 Posted : Wednesday, November 19, 2008 5:16:56 PM(UTC)
Glenvan
Thanks, I will try that. The model number is GU2700XTSB1. If the drain line is plugged, is there a way to reset the control panel?
#4 Posted : Thursday, November 20, 2008 1:32:01 AM(UTC)
Reread your post and I apologize, I messed up. Must of had my head up my ---; well you know where!!!
Here is a link to your parts
Model GU2700XTSB1
In this case the first thing I would check would be the thermal fuse on the control board. Item 6 in the "Control panel parts" section.
Here is the tech sheet
https://www.servicematters.com/d...heet%20-%20W10130990.pdf
It and the door switch will kill all power to the unit.
Glenvan
#5 Posted : Sunday, November 23, 2008 8:18:24 PM(UTC)
Glenvan
Thanks, that makes more sense. I will replace the fuse.
Dishwasher is dead (Dishwasher Repair)
by glendapeck 12/10/2011 2:59:41 AM(UTC)
Control Panel on my Maytag Dishwasher is dead (Dishwasher Repair)
by mauryb 5/22/2011 6:56:27 AM(UTC)
kenmore dishwasher is dead (Dishwasher Repair)
by partyguy3800 6/26/2009 3:34:40 PM(UTC)
by rchiga 9/12/2007 7:51:48 AM(UTC)
