iatia
#1 Posted : Thursday, December 6, 2007 5:41:21 PM(UTC)
iatia
:mad: I have a whirlpool super capacity 465 and the oven door came off unexpectedly while I was cleaning the stove after a repair:eek:. Now leads me to two more repairs.:( one is trying to get the oven door back where it belongs:rolleyes: and finding where I can purchase the two side pieces of door trim:confused: . I have read other threads where they had the same problem with their oven door, but it was a different model and even though the springs looked similar they are different:cool:. Is there a certain way this door re-attaches:confused:? Thanks for any light you might shed on this mess:D.
iatia
#2 Posted : Friday, December 7, 2007 12:39:18 PM(UTC)
You can find the instructions how to remove and/or reinstall the oven door in the "Use and care" book (page 26).
You can look up parts for the door on the door break down diagram.
- Here are the break down diagrams for the Whirlpool range Model SF315PEEW0
iatia
#3 Posted : Friday, December 7, 2007 4:00:26 PM(UTC)
iatia
Thanks Gene, for the info and picture. I read the other treads about oven door horror and they had the same thing to say "what hole"? Well I assumed that there had to be a hole somewhere on the spring and when I was able to pull it open further, there it was and then it was nice going. Thanks man, what power there is in knowledge.:D Later!
lmjiv
#4 Posted : Monday, November 17, 2008 7:47:36 PM(UTC)
lmjiv
Thank you Gene for this most helpful info. I wish you and your family all the best.
#5 Posted : Monday, November 17, 2008 7:56:18 PM(UTC)
You are very welcome.
Viking Oven door opens only 1/2 in. Did not use self -clean (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 1:50:17 PM(UTC)
Oven door almost opens (Oven Repair (including Ranges and Cooktops))
by hasyed 3/30/2023 1:13:59 PM(UTC)
Maytag wall oven door won't unlock (Oven Repair (including Ranges and Cooktops))
by Guest 9/13/2022 10:44:59 AM(UTC)
Frigidaire GLGFS66.ABB Oven Door Sticks at Broil Stop Position (Oven Repair (including Ranges and Cooktops))
by gdaarob 3/28/2022 6:15:15 AM(UTC)
Jennaire JGS8860BDP oven door (Oven Repair (including Ranges and Cooktops))
by df911 11/4/2021 9:38:06 AM(UTC)
Need help with repair of Kenmore built in oven door handle repair 91141065791 (Oven Repair (including Ranges and Cooktops))
by Notacook 10/27/2021 5:49:46 PM(UTC)
REPLACE OVEN DOOR OUTER GLASS FRIDGAIR ELECTRIC RANGE MODELFEF357BBA (Oven Repair (including Ranges and Cooktops))
by Guest 5/3/2021 12:14:15 PM(UTC)
Frigidaire oven door hinge not locking (Oven Repair (including Ranges and Cooktops))
by jacobrobbins219 3/16/2021 5:42:08 PM(UTC)
Oven Door Locked - No Power (Oven Repair (including Ranges and Cooktops))
by Nothing Finer 10/26/2020 3:33:54 PM(UTC)
Samsung - Oven Door Won't Close Tight (Oven Repair (including Ranges and Cooktops))
by Samich 4/26/2020 7:59:48 AM(UTC)
Kitchenaid wall oven door locked (Oven Repair (including Ranges and Cooktops))
by mdawley 3/6/2020 9:40:01 AM(UTC)
Whirlpool Wall Oven Door Locked and No Power (Oven Repair (including Ranges and Cooktops))
by sunia 11/14/2019 7:10:53 AM(UTC)
Where Online Can I Find Compatible DCS (Fisher & Paykel) Oven Door Hinges? (Refrigerator & Freezer Repair)
by WestLA 8/19/2019 10:57:44 AM(UTC)
Replace oven door assembly or outer tempered glass (Oven Repair (including Ranges and Cooktops))
by Jkaup 6/15/2019 8:29:47 AM(UTC)
Oven Door still will not close after hinge and seal replacement (Oven Repair (including Ranges and Cooktops))
by Ten13 3/18/2019 8:45:03 AM(UTC)
