GRAMCRACKER
#1 Posted : Thursday, May 26, 2011 7:34:14 AM(UTC)
GRAMCRACKER
I Would Like Instructions On Removing The Control Panel On This Model To Repair The Latch Assembly
Joe / APP Team
#2 Posted : Thursday, May 26, 2011 11:18:15 AM(UTC)
Joe / APP Team
Gramcracker,
You don't have to remove the control panel, you remove the plastic inner door liner.
Here are the instructions from the service manual,
Inner Door Panel
Removal of the Inner Door Panel will allow access to the Microprocessor Board, Door Switches, Detergent / Rinse Aid Dispenser, and Vent Assembly.
Removal
1. Disconnect power to the machine.
2. Open the Dishwasher door.
3. Remove the 11 Torx™ screws along the sides and
top of the Inner Door Panel.
4. Separate the Inner Door Panel from the Outer Door.
5. Disconnect wires from the Vent and Dispenser Wax
Motors before pulling the Inner Door Panel away
from the Dishwasher.
2. Remove the Inner Door Panel. (See paragraph Inner
Door Panel removal).
3. Lift Door Latch Assembly out.
Switch Removal
3. Remove Door Latch and Switch Holder Assembly.
4. Depress locking tabs and lift switch from holder.
Good Luck,
