ElvisPresley
#1 Posted : Monday, November 17, 2008 7:12:12 AM(UTC)
ElvisPresley
made by fridgedaier. just replaced the felt this weekend, so i know how to open it up. lint is all cleaned out of the ductwork.
heats up for awhile then quits heating. Figure it needs a coil kit or thermostat. how do i tell which part it needs? which is the most likely to fail?
I know this is not crummy dryer, but i'd rather not by another one.
magician59
#2 Posted : Monday, November 17, 2008 9:16:20 AM(UTC)
magician59
More likely to be the cycling thermostat. As a preventive, I always replace all the thermostats.
kayakcrzy
#3 Posted : Monday, November 17, 2008 3:44:55 PM(UTC)
kayakcrzy
I'll bet dollars to donuts it is the coils on the gas valve. Tom ApplianceEducator.com
ElvisPresley
#4 Posted : Wednesday, November 19, 2008 6:24:08 AM(UTC)
ElvisPresley
kayakcrzy--
you were right--it was the coils on the gas valve.
THANKS!
Ben
kayakcrzy
#5 Posted : Thursday, November 20, 2008 4:27:41 AM(UTC)
kayakcrzy
Good Job!!! I bet that was the cheapest dryer repair you ever had. That is the way to save the cash. Tom ApplianceEducator.com
