dieselgg
#1 Posted : Sunday, November 16, 2008 11:23:04 AM(UTC)
dieselgg
This model may not be recognized in this forum as it is a CDN model WEP83801. It is an electric range with a CERAN top, the knobs are rotary and there is an LCD display in the middle that shows the time, and has buttons on either side for setting the oven timer.
Basically, when I set the control knob to Bake, and then the temp knob to say 350F, it works fine for a while and then the bake light goes out. I open the oven door and the bottom filament goes out. I have to move the temp button to say 400F for the Bake light to come back On and then move it back a bit to about 375F to get as close to 350F without the Bake light going out again and of course the bottom filament also. But again, after a while, (the time can vary), the Bake light goes Off again.
Also the knob to set the oven to Bake seems not properly aligned with label 'Bake'. It looks to be off a bit.
Any suggestions would be appreciated.
#2 Posted : Monday, November 17, 2008 12:07:14 PM(UTC)
Most likely the problem is a bad control board (aka a timer). You can find the break down diagrams and part numbers here.
dieselgg
#3 Posted: : Monday, November 17, 2008 12:26:13 PM(UTC)
dieselgg
thanks for your help Gene
