Kford
#1 Posted : Monday, November 17, 2008 11:17:04 AM(UTC)
Kford
My Roper washer wont work once it gets past the rinse cycle. It quits??? How do I tell if its the switch or something else
magician59
#2 Posted : Monday, November 17, 2008 12:23:42 PM(UTC)
magician59
Does it go through the first spin?
libertyappl
#3 Posted : Monday, November 17, 2008 12:24:39 PM(UTC)
libertyappl
I suggest checking your pump for an obstruction.
Nat
Kford
#4 Posted : Tuesday, November 18, 2008 7:36:25 AM(UTC)
Kford
It aggitates the laundry, you can hear the timer working as the dial is moving on the machine. Then just before the rinse cycle it aggitates the laundry again then it quits. You don't hear the timer and it doesnt drain to start the rinse cycle
magician59
#5 Posted : Tuesday, November 18, 2008 8:03:23 AM(UTC)
magician59
Check the lid switch.
Roper washer wont drain or spin (Washer Repair)
by tj1217 8/13/2014 6:33:05 AM(UTC)
Roper Washer Wont Drain (Washer Repair)
by REPAIRTHIS 4/26/2011 5:49:21 PM(UTC)
Roper Washer Wont Drain or Agiate and hums from Power Knob (Washer Repair)
by Rho 8/3/2009 10:10:05 AM(UTC)
