PapaRoro
#1 Posted : Wednesday, May 25, 2011 12:02:37 PM(UTC)
PapaRoro
I purchesed and installed a Indoor Soap dispenser from you and my wife says it doesn't work. The machine cycles but the door does not open. This is such a simple switch I don't understand, can I check it with an ohmmeter or power down and power up the machine or what ? I also replaced the inlet valve at the same time.
Thanks, PapaRoro :confused:
#2 Posted : Wednesday, May 25, 2011 4:12:16 PM(UTC)
What was the problem before you replaced the soap dispenser?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL DU1100XTPQA UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
PapaRoro
#3 Posted : Wednesday, May 25, 2011 5:09:07 PM(UTC)
PapaRoro
I don't know other than she said it "never worked right" she thought the h2o pressure forced it open so when we lost pressure it didn't work. After I replaced the inlet valve I decided to replace the dispenser. This is a simple electric latch that I think is triggered by the by the wash cycle that sends a signal to the latch.
#4 Posted : Thursday, May 26, 2011 12:49:34 PM(UTC)
Open the door during the wash cycle and check if the middle spray arm (under the upper dish rack) is spinning properly. Also check if the dishes on the upper rack are wet.
"never worked right" is not much information. If you would like to fix the dishwasher and make your wife happy, you have to diagnose it yourself.
