I need to replace the lid switch in me washer and I can't seem to figure out how to get to the connector for the switch. Where are the screws/clips to remove the control panel?
Originally Posted by: davet_1961 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I need to replace the lid switch in me washer and I can't seem to figure out how to get to the connector for the switch. Where are the screws/clips to remove the control panel? Dave, You'll need to "open" the control panel and remove the cabinet to change out the lid switch assembly, Here's some information that should help, 1. Remove the two Phillips-head screws securing the front corners of the console to the washer top.(the 2 screws could also be located on the backside of the end caps, or under the plastic end cap trim strip). 2. Tip the console back on the hinges that secure the top of the console to the washer back. ACCESSING COMPONENTS INSIDE THE WASHER CABINET Components inside the washer cabinet can be accessed by completely removing the outer cabinet as one unit. 1. Remove the console mounting screws and tilt the console into the service position. 2. Unplug the lid switch harness connector from the receptacle in the washer top. 3. Remove the cabinet mounting clips by placing the flat blade of a screwdriver in the clip (push down and pry out towards the back of the washer)to un hook the clip. 4. Remove the cabinet by tilting it forward and pulling it away from the washer. Good Luck, :) :) :)
