Pat721
#1 Posted : Monday, November 17, 2008 7:36:00 AM(UTC)
Pat721
We had been smelling gas for a couple of days. The gas company checked our stove and found that the knobs on the front of the stove were in his words seeping gas. what do I need to replace? I didn't want to buy a new stove.
Thanks:confused:
#2 Posted : Tuesday, November 18, 2008 1:00:43 PM(UTC)
Remove all burners. Lift up the top panel and, using a soapy water, check all gas line connections and gas valves for a bubbles. Post the results.
Here are the break down diagrams for the Amana range Model ARG7300LL
P.S. Do not forget to unplug the range first.
Pat721
#3 Posted : Tuesday, November 18, 2008 1:43:34 PM(UTC)
Pat721
Thank you so much for the quick reply. I will try that and let you know what happened.
Pat721
