I have a Frigidaire refrigerator/freezer (side-by-side) Model FRS6LR5EM6 with ice and water dispenser. The burned out light bulb for the water dispenser broke during removal. How do I remove the broken bulb so that I can replace ir?
Thanks, Ray Savage
Unplug the machine. Use a needle nosed plier to grasp what remains of the bulb and remove it.
Thanks for yor reply. The cramped space does not allow me to use needle nosed pliars.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
That happened to me and I had to take the cover off and pop out the plastic receptacle and it was easy after that. I couldn't get the remnant of the bulb out any other way
