Resin
#1 Posted : Tuesday, May 24, 2011 10:17:13 AM(UTC)
Resin
Just moved into a condo, couple issues with the stove. The front two burners can't keep a temperature, they both turn off and on. Do I need to replace the burners or is it something else? Also, the drawer won't close right and I found these.
UserPostedImage
#2 Posted : Tuesday, May 24, 2011 2:18:02 PM(UTC)
The model number you posted is incomplete. Verify and repost it please.
Resin
#3 Posted : Tuesday, May 24, 2011 8:00:33 PM(UTC)
Resin
665.9580.4000
#4 Posted : Tuesday, May 24, 2011 9:55:29 PM(UTC)
Resin,
All surface burners in your stove should cycle on and off, even on the Hi setting, to protect the glass top from overheating.
The two pieces on the picture are the drawer support rollers. Looks like they are damaged and you need to order two new. The installation instructions included.
- The drawer roller kit (two needed) Part number: AP2994446
Kenmore Stove Help (Oven Repair (including Ranges and Cooktops))
by jon1984 8/26/2008 8:03:26 AM(UTC)
